HP EliteBook 850 G7 Battery Replacement
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
The battery can now be removed
For reassembly just follow the directions in reverse
