Zum Hauptinhalt wechseln
HP EliteBook 8560w Memory Replacement
Alexandre  Mota
Alexandre Mota und 2 weitere Mitwirkende
Zuletzt aktualisiert am April 27, 2020
30 Minuten
Mittel
Hello, this guide will help you replace the memory in a HP EliteBook 8560w.
Keep in mind that this model has two pairs of memory: one pair below the back panel and another below the keyboard. We’ll describe the steps for both.
Usually, a computer’s memory needs to be replaced when a message of “not enough memory” pops up in your screen. However, check out our troubleshooting page to see if your problem falls into a different category.
Please follow instructions as they appear.
Was du brauchst
Werkzeuge
  1. HP EliteBook 8560w Memory Replacement, Battery: Schritt 1, Bild 1 von 2 HP EliteBook 8560w Memory Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Memory Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out.
  3. HP EliteBook 8560w Memory Replacement, Back Panel: Schritt 3, Bild 1 von 2 HP EliteBook 8560w Memory Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Memory Replacement: Schritt 4, Bild 1 von 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Memory Replacement, CD/DVD ROM: Schritt 5, Bild 1 von 2 HP EliteBook 8560w Memory Replacement, CD/DVD ROM: Schritt 5, Bild 2 von 2
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w Memory Replacement: Schritt 6, Bild 1 von 3 HP EliteBook 8560w Memory Replacement: Schritt 6, Bild 2 von 3 HP EliteBook 8560w Memory Replacement: Schritt 6, Bild 3 von 3
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w Memory Replacement: Schritt 7, Bild 1 von 2 HP EliteBook 8560w Memory Replacement: Schritt 7, Bild 2 von 2
    • Pull out the CD/DVD ROM with your hand.
  8. HP EliteBook 8560w Memory Replacement, Keyboard: Schritt 8, Bild 1 von 1
    • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
  9. HP EliteBook 8560w Memory Replacement: Schritt 9, Bild 1 von 3 HP EliteBook 8560w Memory Replacement: Schritt 9, Bild 2 von 3 HP EliteBook 8560w Memory Replacement: Schritt 9, Bild 3 von 3
    • Put your finger through the hole to push out the keyboard from its place.
    • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
  10. HP EliteBook 8560w Memory Replacement: Schritt 10, Bild 1 von 3 HP EliteBook 8560w Memory Replacement: Schritt 10, Bild 2 von 3 HP EliteBook 8560w Memory Replacement: Schritt 10, Bild 3 von 3
    • Carefully lift keyboard to reveal connection strips.
    • Unlock the latch holding the connection strips.
    • Pull out the connection strips from the motherboard.
  11. HP EliteBook 8560w Memory Replacement, Memory: Schritt 11, Bild 1 von 3 HP EliteBook 8560w Memory Replacement, Memory: Schritt 11, Bild 2 von 3 HP EliteBook 8560w Memory Replacement, Memory: Schritt 11, Bild 3 von 3
    • Your HP EliteBook 8560w has two pairs of RAM: one below the keyboard and the other below the back panel. This guide begins removing the pair below the keyboard, then proceeds to the one below the back panel.
    • Pull both metal parts away from memory pair. Lift memory pair and it will come out.
  12. HP EliteBook 8560w Memory Replacement: Schritt 12, Bild 1 von 3 HP EliteBook 8560w Memory Replacement: Schritt 12, Bild 2 von 3 HP EliteBook 8560w Memory Replacement: Schritt 12, Bild 3 von 3
    • Flip device upside down. Pull metal bars away from the memory. Lift the memory up and it will pop out.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
The best explanation to a memory replace ever! Congratulations!
Please! Do the same to a graphic card replace for HP 8560W!! Please..PLease...
And, I have a question: MAY I INSTALL AN MSATA HARD DISK ON WWAN SLOT from this machine HP 8560W Elitebook workstation??? May I?
l g - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 2,054
