Zum Hauptinhalt wechseln
HP Envy 15-u001dx Wireless Network Card Replacement
Dakota Presley
Dakota Presley und 4 weitere Mitwirkende
Zuletzt aktualisiert am January 3, 2022
Keine Schätzung
Mittel
Falsche Werkzeuge
Bessere Einleitung
Was du brauchst
Werkzeuge
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. HP Envy 15-u001dx Wireless Network Card Replacement, HP Envy 15-u001dx Disassembly: Schritt 1, Bild 1 von 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Wireless Network Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Wireless Network Card Replacement: Schritt 3, Bild 1 von 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Wireless Network Card Replacement: Schritt 4, Bild 1 von 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Wireless Network Card Replacement: Schritt 5, Bild 1 von 2 HP Envy 15-u001dx Wireless Network Card Replacement: Schritt 5, Bild 2 von 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Wireless Network Card Replacement, Wireless Network Card: Schritt 6, Bild 1 von 1
    • Remove the Phillips #0 4.5 mm screw from the wireless network card located in the back, right side of the interior.
  7. HP Envy 15-u001dx Wireless Network Card Replacement: Schritt 7, Bild 1 von 1
    • Use the spudger to remove the antenna connector attached to the black wire labeled "1".
  8. HP Envy 15-u001dx Wireless Network Card Replacement: Schritt 8, Bild 1 von 1
    • Detach the antenna connector for the white wire labeled "2".
  9. HP Envy 15-u001dx Wireless Network Card Replacement: Schritt 9, Bild 1 von 1
    • Gently remove the card from its slot by pulling.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 9-4, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 625
