Zum Hauptinhalt wechseln
HP Envy 17m-ae111dx Hard Drive Replacement
Kyle Fox
Kyle Fox und 2 weitere Mitwirkende
Zuletzt aktualisiert am November 15, 2022
20 - 25 Minuten
Mittel
The Hard Drive or Solid State Drive (SSD) is the physical device that stores your data on your computer. This guide will show you how to replace it starting from a fully assembled device. You will need a Hard Drive or SSD to complete this guide and replace the current Hard Drive. You will need is the iFixit Opening Tool,  a 00 Phillips-head Screwdriver, and a T5 Torx-Head Screwdriver.
Was du brauchst
Komplettpaket für die Reparatur
Diese Kits enthalten alle Ersatzteile und Werkzeuge, die für diese Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. HP Envy 17m-ae111dx Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop on its back.
  2. HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the plastic covering to the Disk Reader.
    • Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
    • If the button on the side is jammed, pry off the covering by using the iFixit Opening Tool.
  3. HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Unscrew all visible screws.
    • Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
    • One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
  4. HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 4, Bild 1 von 2 HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Pry the gripper completely off to expose the two screws.
    • Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
  5. HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Use the iFixit opening tool to pry off the back cover.
    • Ensure that you go all the way around the laptop with the tool to take it off.
  6. HP Envy 17m-ae111dx Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 3 HP Envy 17m-ae111dx Hard Drive Replacement, Hard Drive: Schritt 6, Bild 2 von 3 HP Envy 17m-ae111dx Hard Drive Replacement, Hard Drive: Schritt 6, Bild 3 von 3
    • Unplug the cable that connects the hard drive to the motherboard.
    • Grab from the base of the cable and not from the wire.
  7. HP Envy 17m-ae111dx Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the hard drive from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 50
Insgesamt: 5,248
