Zum Hauptinhalt wechseln
HP Envy x360 15-bp143cl Motherboard Replacement
Thomas Schemm
Thomas Schemm und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 17, 2025
30 - 45 Minuten
Mittel
Bessere Einleitung
This guide will show you how to replace the motherboard on your HP Envy laptop. There are two main reason for doing this, you can upgrade your board, or fix a bad one. Without further ado, let us begin.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP Envy x360 15-bp143cl Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 5, Bild 1 von 2 HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Peel off the tape securing the heatsink.
  8. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the seven 4 mm screws securing the fan.
    • Detach the fan cable from the mother board.
  9. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Lift the fan up and off the motherboard.
  10. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the ten 4 mm screws securing the motherboard.
    • Pull the four cables directly out of their ports.
    • Flip up the lock-bar on the two ZIF connectors, then gently pull the two ribbon cables directly out of their ports.
  11. HP Envy x360 15-bp143cl Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the motherboard up and out of the chassis.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 45
Insgesamt: 1,133
