Zum Hauptinhalt wechseln
HP Envy x360 15-u473cl Touch Screen Replacement
Maximillian McDonald
Maximillian McDonald und eine weitere beteiligte Person
Zuletzt aktualisiert am June 11, 2018
20 - 25 Minuten
Schwierig
The touch screen can be damage or wear out over time. This guide will show how to replace the touch screen of your device.
Was du brauchst
Ersatzteile
Werkzeuge
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
Mehr anzeigen …
  1. HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: Schritt 1, Bild 1 von 2 HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: Schritt 1, Bild 2 von 2
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. HP Envy x360 15-u473cl Touch Screen Replacement: Schritt 2, Bild 1 von 1
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. HP Envy x360 15-u473cl Touch Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  4. HP Envy x360 15-u473cl Touch Screen Replacement: Schritt 4, Bild 1 von 2 HP Envy x360 15-u473cl Touch Screen Replacement: Schritt 4, Bild 2 von 2
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 13,010
