Zum Hauptinhalt wechseln
HP Pavilion 11-n010dx Fan Replacement
Joseph Lintz
Joseph Lintz und 2 weitere Mitwirkende
Zuletzt aktualisiert am September 29, 2024
5 - 15 Minuten
Leicht
This guide will instruct a user on how to remove the fan in order to replace a potentially faulty piece of hardware. Be sure the device is turned off and disconnected from all power sources.
Was du brauchst
Werkzeuge
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Mehr anzeigen …
  1. HP Pavilion 11-n010dx Fan Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 11-n010dx Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Fan Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 11-n010dx Fan Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 11-n010dx Fan Replacement: Schritt 2, Bild 3 von 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Fan Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 11-n010dx Fan Replacement: Schritt 3, Bild 2 von 2
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Fan Replacement: Schritt 5, Bild 1 von 2 HP Pavilion 11-n010dx Fan Replacement: Schritt 5, Bild 2 von 2
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Fan Replacement: Schritt 6, Bild 1 von 2 HP Pavilion 11-n010dx Fan Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Fan Replacement, Fan: Schritt 8, Bild 1 von 1
    • Use the Phillips #0 to remove the two 3mm screws holding the fan in place.
  9. HP Pavilion 11-n010dx Fan Replacement: Schritt 9, Bild 1 von 3 HP Pavilion 11-n010dx Fan Replacement: Schritt 9, Bild 2 von 3 HP Pavilion 11-n010dx Fan Replacement: Schritt 9, Bild 3 von 3
    • Use the plastic opening tool to slowly loosen the connection cable.
    • Once the connector is loose enough, grab the cable and carefully pull it free from your device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Joseph Lintz
939 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 11-5, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 688
