Zum Hauptinhalt wechseln
HP Pavilion 15-au123cl Battery Replacement
Mohammad Gardezi
Mohammad Gardezi und 4 weitere Mitwirkende
Zuletzt aktualisiert am September 14, 2021
10 - 15 Minuten
Mittel
We will be removing the back panel and then removing the battery. Before you do any major hardware modifications to the laptop, it is important to remove the battery first. Once removed, further modifications are much safer.
Was du brauchst
Werkzeuge
Einführungsvideo
  1. HP Pavilion 15-au123cl Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-au123cl Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Battery Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-au123cl Battery Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Battery Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-au123cl Battery Replacement: Schritt 4, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Battery Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-au123cl Battery Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-au123cl Battery Replacement: Schritt 5, Bild 3 von 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
Abschluss
18 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S13-G3, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Mitglieder
6 Anleitungen geschrieben
6 Kommentare
That one screw under the rubber pad is a special kind of BS.
Liam Kosloski - Antwort
The screw in the middle of everything was hardest for me to reinstall because it has to hold the CD drive in place ,and that drive hole must line up with everything else _just right_. Also, prying the keyboard from the shell was harder than I expected. It’s snapped in there pretty tight.
kctipton - Antwort
The procedure should be modified to start with removing the center screw that retains the DVD drive and then pulling out the drive. That makes separating the case halves easier.
George Mells - Antwort
My problem on ebay and amazon i only got aftermarket battery they claim oem 849909-850
I BOUGHT 3 SO FAR SAME THING …HP SAYS THEY DONT HAVE THE BATTERY FOR SALE ANY LONGER
Laptop wont start with nee battery … i conect old one with power on , once start conect new one and works
When shutdown or sleep it wont start with new battery
Will restart with new battery and last up to 6 hours new battery but wont start.
How can i start my laptop with new battery ?
Juan Carlos Gomez - Antwort
It would be useful to have a heads up on how to get the CD/DVD drive back in place. I found ejecting the CD tray before shutdown and disassembly gave me some wiggle room when reinstalling. Then, you have to slide the CD plug into the motherboard jack before snapping the back cover into place. Make sure the screw hole on the CD drive aligns properly with the screw hole on the motherboard.
Also, my battery had 3 screws; one at the "top," one at each bottom corner.
John Darago - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 46
Insgesamt: 24,384
