Zum Hauptinhalt wechseln
HP Pavilion 15-au123cl Motherboard Replacement
Joseph Nicholson
Joseph Nicholson und eine weitere beteiligte Person
Zuletzt aktualisiert am December 20, 2019
10 - 35 Minuten
Mittel
Action Shots
Benötigt Bessere Bilder
Benötigt Mehr Bilder
Bessere Einleitung
This guide will display how to replace the motherboard of the HP Pavilion 15-au123cl Laptop. The replacement is not hard, but will require the removal of the fan, network card, and battery beforehand.
Was du brauchst
Werkzeuge
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  • Small Plastic Spudger
Mehr anzeigen …
  1. HP Pavilion 15-au123cl Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Motherboard Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Motherboard Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Motherboard Replacement, Network Card: Schritt 6, Bild 1 von 3 HP Pavilion 15-au123cl Motherboard Replacement, Network Card: Schritt 6, Bild 2 von 3 HP Pavilion 15-au123cl Motherboard Replacement, Network Card: Schritt 6, Bild 3 von 3
    • The network card is located at the top left corner of the motherboard.
    • Unscrew the 4.4mm PH0 Phillips screw at the top of the network card.
  7. HP Pavilion 15-au123cl Motherboard Replacement: Schritt 7, Bild 1 von 3 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 7, Bild 2 von 3 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Using the spudger, remove the two gold pins at the top of the network card.
    • It is recommended to gently apply a vertical force upward with the spudger.
  8. HP Pavilion 15-au123cl Motherboard Replacement: Schritt 8, Bild 1 von 3 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 8, Bild 2 von 3 HP Pavilion 15-au123cl Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Lift up the network card and remove it from the motherboard connector.
  9. HP Pavilion 15-au123cl Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Firmly disconnect the fan from the motherboard.
    • Remove the three screws from the fan using a Philips #0 Screwdriver.
  10. HP Pavilion 15-au123cl Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the six screws from the motherboard using a Philips #0 Screwdriver.
  11. HP Pavilion 15-au123cl Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the ribbon cables from the motherboard.
    • Remove the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
buenas tardes : Nesecito saber donde puedo conseguir el Motherboard para una HP Pavilion Y1N95UA 15-AU123CL descrito en este posteo ..
Saludos Gabriel Angel..!!!
Gabriel Antonielli - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 1,950
