Zum Hauptinhalt wechseln
HP Pavilion 15-ba003ds Backplate Replacement
Krushnam Badami
Krushnam Badami und 4 weitere Mitwirkende
Zuletzt aktualisiert am June 19, 2020
6 - 10 Minuten
Sehr einfach
Studierende im Gange!
This guide will detail how you can get into the HP Pavilion 15-ba003ds by providing you the steps to follow in order to safely remove the back plate from your laptop. This guide may be of use to you should you need to have access to the internal components of your laptop for any repair, replacements, or cleaning of the laptop.
Was du brauchst
Werkzeuge
  1. HP Pavilion 15-ba003ds Backplate Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 15-ba003ds Backplate Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Backplate Replacement, Disc Drive: Schritt 2, Bild 1 von 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Backplate Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-ba003ds Backplate Replacement: Schritt 3, Bild 2 von 2
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Backplate Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-ba003ds Backplate Replacement: Schritt 4, Bild 2 von 2
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
  5. HP Pavilion 15-ba003ds Backplate Replacement, Backplate: Schritt 5, Bild 1 von 3 HP Pavilion 15-ba003ds Backplate Replacement, Backplate: Schritt 5, Bild 2 von 3 HP Pavilion 15-ba003ds Backplate Replacement, Backplate: Schritt 5, Bild 3 von 3
    • Use a Jimmy to pry off the black backplate.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
York University, Team S1-G9, Woodhouse Winter 2020 Mitglied von York University, Team S1-G9, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G9
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 18
Insgesamt: 538
