HP Pavilion dv6-6117dx RAM Replacement
Einleitung
Zu Schritt 1 der AnleitungIs your computer running slow? One cause could be an insufficient amount of RAM. By following this guide below, you can upgrade the RAM in your HP Pavilion dv6-6117dx to help give your computer a breath of fresh air.
Was du brauchst
Werkzeuge
Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
Slide a black spudger under the top of the cover to loosen the clips underneath.
Slide the spudger down the left side of the cover to loosen the clips.
After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
