HP Pavilion dv7-4285dx Hard Drive Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will describe how to replace the hard drive of the HP Pavilion dv7-4285dx
Was du brauchst
Slide the battery release switch to the left. The battery pack will then subsequently release.
Unscrew the 5 back plate screws using a Phillips #0 screwdriver.
Remove back plate using a metal spudger.
Remove the four 5.7 mm screws, holding down the hard drive, using a Phillips #0 screwdriver.
Pull up carefully on tab hooking the hard drive to the mother board.
Remove the hard drive.
