Zum Hauptinhalt wechseln
HP Pavilion x360 14-ba253cl Battery Replacement
ryan reichard
ryan reichard und 4 weitere Mitwirkende
Zuletzt aktualisiert am January 3, 2024
10 Minuten
Leicht
Fehlende Schritte
Use this guide to replace your battery in your HP Pavilion laptop.
Note: This guide is written for the HP Pavilion x360 14-ba253cl model.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
Was du brauchst
Fix Kit
Dieses Kit enthält alle Ersatzteile und Werkzeuge, die für die Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: Schritt 3, Bild 1 von 1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: Schritt 4, Bild 1 von 1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: Schritt 5, Bild 1 von 1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: Schritt 6, Bild 1 von 1
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: Schritt 7, Bild 1 von 1
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Thanks, it was useful
Oleg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 40
Letzte 30 Tage: 126
Insgesamt: 9,482
