Zum Hauptinhalt wechseln
HP Pavilion x360 14m-cd0005dx Back Cover Replacement
Jacob Richardson Earl
Jacob Richardson Earl und eine weitere beteiligte Person
Zuletzt aktualisiert am April 29, 2020
3 - 5 Minuten
Leicht
Use this guide to aid in the removal and replacement of the back cover to any HP Pavilion x360 14m-cd0005dx laptop. If there are ever any cracks or issues with it closing fully, a full replacement might be necessary.
The back cover is generally removed for any significant modifications or repair to a computer. The back cover comes off and goes back on relatively quickly. Luckily, replacing the back cover is reasonably quick and easy; it also has minimal risk of damage to the device.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP Pavilion x360 14m-cd0005dx Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: Schritt 3, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: Schritt 4, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: Schritt 5, Bild 3 von 3
    • Using the opening tool, carefully remove the bottom cover from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 31
Insgesamt: 3,668
