Zum Hauptinhalt wechseln
HP Pavilion x360 14m-cd0005dx Battery Replacement
Jacob Richardson Earl
Jacob Richardson Earl und eine weitere beteiligte Person
Zuletzt aktualisiert am April 29, 2020
5 - 10 Minuten
Leicht
Empfohlene Anleitung von Studierenden
Use this guide to aid in the removal and replacement of the battery to any HP Pavilion x360 14m-cd0005dx laptop. The battery should be replaced if the computer cannot stay charged during use or cannot charge at all. For further information as to whether the battery should be replaced, look at this troubleshooting guide.
The battery is an essential part of any laptop as it is the primary source of power. If the battery malfunctions, then the device only powers on while plugged into a wall socket. When the battery is replaced, an increase in computer performance can sometimes be seen. If a laptop battery needs to be replaced but isn’t, further damage to the system can occur.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP Pavilion x360 14m-cd0005dx Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 3, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 4, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 5, Bild 3 von 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: Schritt 6, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: Schritt 6, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: Schritt 6, Bild 3 von 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 7, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift from the base and remove the battery.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,513
