Zum Hauptinhalt wechseln
HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement
Amber Norton
Amber Norton und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 16, 2024
20 Minuten
Leicht
If the touchpad is not responding, learn how to access and remove the part with this guide. The trackpad controls the pointing on a laptop's display screen and can be replaced if it is not picking up your finger movements or downward pressure.
The tools used are the Phillips head screwdriver #0 and #1, the opening picks, tweezers, and the spudger.
This guide involves a number of moving parts, but the steps are easy to follow for someone inexperienced with computer repairs. Keep in mind, organizing the pieces removed allows for an easier reconstruction of the device.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 2, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 2, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the 3 mm screw from the center bottom.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw from all four corners of the bottom cover.
  3. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 3, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 3, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 3, Bild 3 von 3
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 4, Bild 1 von 2 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove all four of the 4 mm screws that secure each corner of the battery.
  5. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 5, Bild 3 von 3
    • Use the opening tool near the connector to gently apply pressure and lift the battery away from the device.
    • Once loose, lift the battery from the connector side to separate it from the device.
    • The stabilizer for the battery (small black part held in by the top left screw) may come loose. Leave the part in its original position.
  6. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Trackpad: Schritt 6, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Trackpad: Schritt 6, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Trackpad: Schritt 6, Bild 3 von 3
  7. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 7, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 7, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 7, Bild 3 von 3
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  8. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 8, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 8, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 8, Bild 3 von 3
  9. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 9, Bild 1 von 2 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 9, Bild 2 von 2
    • Use PH1 to remove all four of the 4mm screws on each corner of the battery.
  10. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 10, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 10, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 10, Bild 3 von 3
  11. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 11, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 11, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 11, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • To unplug the trackpad, remove both stickers with angled tweezers.
    • Lift the connector clasp with spudger.
    • Use angled tweezers to lightly grip the ribbon cable and pull it out to lift cable off of black cover
  12. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 12, Bild 1 von 2 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 12, Bild 2 von 2
    • Using the angled tweezers, grip one corner of the black cover and lift.
  13. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 13, Bild 1 von 1
    • Hold back the black cover with one hand.
    • Use the PH0 screwdriver to remove three black screws (2.5mm) located at the top of the trackpad.
  14. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 14, Bild 1 von 2 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 14, Bild 2 von 2
    • Using the PH1 screwdriver, remove four screws (3mm) at the bottom of the trackpad.
    • Lift the metal cover off.
  15. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 15, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 15, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: Schritt 15, Bild 3 von 3
    • Hold back the black cover.
    • Use the angled tweezers to grip the metal screw tab located in the middle of the trackpad.
    • Lift up and away to remove the trackpad part.
Abschluss
Amber Norton
661 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 30
Insgesamt: 363
