HP dv5-1125nr CMOS Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungThe CMOS battery maintains the computer's startup settings as well as its internal clock. If your computer notifies you about changing this battery, it is best to do so immediately. Use this guide if you need to replace the CMOS battery in your HP dv5-1125nr.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
In diesem Schritt verwendetes Werkzeug:Phillips #00 Screwdriver$5.49
Remove these two 4mm Phillips screws on the back panel using a Phillips #00 screwdriver and remove the cover to reveal the CMOS battery
In diesem Schritt verwendetes Werkzeug:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Locate the CR2032 watch battery
Using a 2.5mm flathead screwdriver, carefully pry up the battery using the tab to the right of the battery
10 weitere Personen haben diese Anleitung absolviert.
