HUAWEI HONOR 5X Speaker Replacement
Einleitung
Zu Schritt 1 der AnleitungIs sound not playing through your speakers? You may need to replace it. This guide will show you how to remove and replace the bottom loudspeaker for the Huawei Honor 5x. If other components of the speaker is not functional then this setup may not fix your problem and you might need to contact help to diagnose the issue.
Was du brauchst
To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
Remove the six Phillips #000 screws holding the speaker to the device.
Remove the speaker
