Wie man das Apple Wireless Keyboard zurücksetzt
Einführungsvideo
Schalte die Tastatur aus, indem du die Power Taste für mindestens 3 Sekunden drückst.
Öffne "Systemeinstellungen...", "Bluetooth"
Um dein Gerät wieder zusammenzubauen, folge den Schritten in umgekehrter Reihenfolge.
5 weitere Personen haben diese Anleitung absolviert.
100%
Hier starten ›
4 Kommentare
I bought a wireless keyboard at a flea market. When pairing I was able to enter all numbers, but the "Enter" key does not react. Is there some way to test the button?
Same for me. The problem was the enter key: there are 2 switches down the key but only the top one is pressed and this is broken. I removed the key, put a plastic spacer on the second switch and reassembled the key, all ok now.
ho provato a resettarla ma niente da fare funziona solo parzialmente .l’ho collegata all’iPad 11 pro e funziona perfettamente
victor
