Zum Hauptinhalt wechseln
How to Repair a Squareplug Patch Cable with SP400 Plugs
Crystal Edwards
Crystal Edwards und 2 weitere Mitwirkende
Zuletzt aktualisiert am March 15, 2023
5 - 10 Minuten
Mittel
If your Squareplug SP400 patch cable isn’t producing clear audio, use this guide to resolder the broken connections.
Patch cables, even well-soldered ones, are susceptible to stress-breaks at their connections. This is usually caused by repeated plugging/unplugging with regular use. A simple resolder with fresh wire ends and solder balls should bring the cable back to life.
Before using this guide, double-check that it’s your patch cable that is faulty. It’s possible the source of the signal loss is elsewhere in the signal chain.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. How to Repair a Squareplug Patch Cable with SP400 Plugs, Patch Cables With SP400 Plugs: Schritt 1, Bild 1 von 1
    • Verify that the cable is faulty (unresponsive yellow and green LED indicators).
    • Yellow LED indicator
    • Green LED indicator
    • If both the yellow and green LED indicators turn on, then the cable is not the source of any audio loss. Check the pedals, amp, guitar, or power supply for issues.
    • If the red LED turns on, then the cable is shorting and will also require a resolder.
  2. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 2, Bild 1 von 1
    • Unscrew the SP400 housing.
  3. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 3, Bild 1 von 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 3, Bild 2 von 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 3, Bild 3 von 3
    • Desolder the existing solder connections.
    • Wick the existing solder completely off of the plug connections.
    • Do not touch the plug or the wick directly while desoldering.
    • For more information on soldering, check out the How to Solder and Desolder Connections guide.
  4. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 4, Bild 1 von 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 4, Bild 2 von 2
    • Cut the ends of the cable using a pair of wire cutters to expose fresh wires.
  5. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 5, Bild 1 von 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 5, Bild 2 von 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 5, Bild 3 von 3
    • Strip the outer insulating jacket by ~1 cm.
    • The Eclipse UTP Stripper works especially well for this step.
    • Braid the ground wires.
  6. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 6, Bild 1 von 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 6, Bild 2 von 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 6, Bild 3 von 3
    • Strip the inner insulator by ~2mm.
    • Braid the signal wires.
  7. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 7, Bild 1 von 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 7, Bild 2 von 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 7, Bild 3 von 3
    • Tin the soldering iron tip, ground wire, signal wire, and plug connections.
    • Do not touch the plug or the solder directly while tinning.
  8. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 8, Bild 1 von 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 8, Bild 2 von 2
    • Solder the wires onto the plug connections:
    • Signal wire to the tip connection
    • Ground wire to the sleeve connection
    • The outer insulating jacket should slightly extend into the chamber of the plug to minimize cable movement.
    • Do not touch the plug directly while soldering.
  9. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 9, Bild 1 von 1
    • Screw the SP400 housing.
  10. How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 10, Bild 1 von 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: Schritt 10, Bild 2 von 2
    • Verify that the cable is working (responsive yellow and green LED indicators).
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 684
