Huawei Y300 Charging Port Replacement
Einleitung
Zu Schritt 1 der AnleitungIn this guide we are going to replace the charging report on the Huawei ascend Y300 android smartphone. Before starting, it is a good idea to prepare an organized area to carry out the repair. It is also helpful to have a way of containing loose screws so they do not become lost. In addition, his guide requires soldering, a “How To” guide is included.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Remove the back plate by hand. There is a small indent on the bottom of the phone to pry open.
Use a T4 Torx screwdriver to remove the 8 screws along the outer edge of the case.
Using the plastic opening tool, pry the screen from the casing. Insert the tool between the case and screen to pry the pieces apart.
3 weitere Personen haben diese Anleitung absolviert.
