Zum Hauptinhalt wechseln
Huawei Y300 SIM Card Replacement
Anthony Ng
Anthony Ng und 2 weitere Mitwirkende
Zuletzt aktualisiert am August 27, 2021
Keine Schätzung
Mittel
Bessere Einleitung
  1. Huawei Y300 SIM Card Replacement, Rear Cover: Schritt 1, Bild 1 von 3 Huawei Y300 SIM Card Replacement, Rear Cover: Schritt 1, Bild 2 von 3 Huawei Y300 SIM Card Replacement, Rear Cover: Schritt 1, Bild 3 von 3
    • First, you want to flip the phone screen facing down. To remove the rear cover located on the back of the phone, you must grip on the gap located at the bottom of the phone. Lastly, pull up!
  2. Huawei Y300 SIM Card Replacement: Schritt 2, Bild 1 von 1
    • In order to remove the battery, you must first locate the gap intended for removal above the battery. You will then push down using the tip of your finger while also pulling outward to remove the battery for replacement.
  3. Huawei Y300 SIM Card Replacement, Replace The Battery: Schritt 3, Bild 1 von 1
    • After the battery is removed, you must replace the battery using the new one. To insert the new battery you must align the connection between the battery and the device. Lastly, you will push the bottom of the new battery until it is sitting inside the intended station.
    • This will be your new source of power.
  4. Huawei Y300 SIM Card Replacement, SIM Card: Schritt 4, Bild 1 von 1
    • Remove the SIM card by sliding it upwards.
    • The gold plate on the SIM card should faced the back of the phone and the little dent sits at the bottom right.
    • Huawei Y300 will not accept micro SIM card.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Anthony Ng
1.445 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G3
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
My Huawei Y300 doesn't read the Sim card when inserted. Why?
Evelyn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 4,933
