Zum Hauptinhalt wechseln
Kobo Clara BW (P365) Power Button Board Replacement
Was du brauchst
  1. Kobo Clara BW (P365) Power Button Board Replacement, Before you begin: Schritt 1, Bild 1 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Before you begin: Schritt 1, Bild 2 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Before you begin: Schritt 1, Bild 3 von 3
    • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
    • Optionally, to drain the battery faster, navigate to MoreSettingsEnergy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
    • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
    • Unplug all cables and fully shut down your eReader.
    • Your screen should be black and say Powered off.
    Frag FixBot
    Kommentar hinzufügen
  2. Kobo Clara BW (P365) Power Button Board Replacement, Insert an opening pick: Schritt 2, Bild 1 von 2 Kobo Clara BW (P365) Power Button Board Replacement, Insert an opening pick: Schritt 2, Bild 2 von 2
    • Lay your eReader down so the back cover is facing up.
    • Insert the flat edge of an opening pick between the frame and the bottom left corner of the back cover.
    • Push the pick downwards at a slight angle until it slides under the back cover.
    Frag FixBot
  3. Kobo Clara BW (P365) Power Button Board Replacement, Release the bottom clips: Schritt 3, Bild 1 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Release the bottom clips: Schritt 3, Bild 2 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Release the bottom clips: Schritt 3, Bild 3 von 3
    • Slide the pick toward the bottom right corner to release the clips along the bottom edge.
    Frag FixBot
  4. Kobo Clara BW (P365) Power Button Board Replacement: Schritt 4, Bild 1 von 2 Kobo Clara BW (P365) Power Button Board Replacement: Schritt 4, Bild 2 von 2
    • Remove the pick and reinsert it under the bottom left corner.
    • Angle the pick flat under the back cover and rotate it around the bottom left corner to release its clips.
    • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
    Frag FixBot
  5. Kobo Clara BW (P365) Power Button Board Replacement, Release the left clips: Schritt 5, Bild 1 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Release the left clips: Schritt 5, Bild 2 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Release the left clips: Schritt 5, Bild 3 von 3
    • Slide the pick toward the top left corner to release the clips along the left edge.
    Frag FixBot
  6. Kobo Clara BW (P365) Power Button Board Replacement, Remove the back cover: Schritt 6, Bild 1 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Remove the back cover: Schritt 6, Bild 2 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Remove the back cover: Schritt 6, Bild 3 von 3
    • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
    • Grip the left edge of the back cover and lift it away from the eReader to release the remaining clips.
    • Remove the back cover.
    • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
    Frag FixBot
  7. Kobo Clara BW (P365) Power Button Board Replacement, Coating information: Schritt 7, Bild 1 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Coating information: Schritt 7, Bild 2 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Coating information: Schritt 7, Bild 3 von 3
    • Nearly the entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
    • While this won't hurt your device, removing the coating compromises the device to potential water damage.
    • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
    • The ZIF connector locking tabs are coated in a gel that can jam the hinge and keep the locking tab from completely unlocking. Make sure the tabs are completely upright before disconnecting any cables.
    • Depending on your repair, you might have to remove the coating completely from the connectors and their cables.
    • If at any point the coating becomes too difficult to work with, heat it for 90 seconds with an iOpener or a hair dryer.
    Frag FixBot
  8. Kobo Clara BW (P365) Power Button Board Replacement, Disconnect the battery: Schritt 8, Bild 1 von 2 Kobo Clara BW (P365) Power Button Board Replacement, Disconnect the battery: Schritt 8, Bild 2 von 2
    • Use a clean fingernail or the flat end of a spudger to pry up and disconnect the battery press connector.
    • Don't pull on what looks like a clear connector pull tab. The tab is secured to the socket gasket.
    Frag FixBot
  9. Kobo Clara BW (P365) Power Button Board Replacement, Disconnect the power button ZIF connector: Schritt 9, Bild 1 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Disconnect the power button ZIF connector: Schritt 9, Bild 2 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Disconnect the power button ZIF connector: Schritt 9, Bild 3 von 3
    • Use the point of a spudger to lift up the locking tab on the power button cable ZIF connector.
    • The locking tab should be nearly vertical when unlocked. If it isn't, gently push the tab forward to compress the waterproofing gel and unlock the tab.
    • Use a pair of blunt nose tweezers to grip the cable close to the head and pull it away from its ZIF connector slowly and steadily to separate the coating.
    • During reassembly:
    • Inspect the head of the cable and the ZIF connector for any remaining coating that could prevent a good connection.
    • Peel off the coating—heating the cable and the ZIF connector when the coating becomes too brittle.
    • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in its connector.
    Frag FixBot
  10. Kobo Clara BW (P365) Power Button Board Replacement, Separate the power button adhesive: Schritt 10, Bild 1 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Separate the power button adhesive: Schritt 10, Bild 2 von 3 Kobo Clara BW (P365) Power Button Board Replacement, Separate the power button adhesive: Schritt 10, Bild 3 von 3
    • Insert an arm of a pair of sharp tweezers under the edge of the power button board.
    • Slide the arm along the edge of the board to separate enough adhesive to fit an opening pick under the board.
    Frag FixBot
  11. Kobo Clara BW (P365) Power Button Board Replacement: Schritt 11, Bild 1 von 3 Kobo Clara BW (P365) Power Button Board Replacement: Schritt 11, Bild 2 von 3 Kobo Clara BW (P365) Power Button Board Replacement: Schritt 11, Bild 3 von 3
    • Insert the tip of an opening pick underneath the power button board.
    • Slide the pick along the edge of the power button board to separate the adhesive.
    • Gently twist the pick to separate the adhesive on both sides.
    Frag FixBot
  12. Kobo Clara BW (P365) Power Button Board Replacement, Remove the power button board: Schritt 12, Bild 1 von 2 Kobo Clara BW (P365) Power Button Board Replacement, Remove the power button board: Schritt 12, Bild 2 von 2
    • Peel the power button board up and off of the frame to remove it.
    • During reassembly, follow this guide to transfer your power button board to a new screen or to install a new one.
    Frag FixBot
Abschluss
Remember: after repairs, your eReader is no longer IPX8 waterproof.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Make sure each of your device's main functions still work, e.g., LED backlight, touch, Wi-Fi, etc.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Carsten Frauenheim
166.817 Reputation
439 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
27.524 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 51
Insgesamt: 433
