Zum Hauptinhalt wechseln
Lenovo V14-IIL Screen Bezel Replacement
Kristen Gismondi
Kristen Gismondi und 2 weitere Mitwirkende
Zuletzt aktualisiert am March 3, 2025
20 - 30 Minuten
Mittel
Studierende im Gange!
Bessere Einleitung
Fehlende Angaben
Is the screen bezel on your Lenovo V14-IIL damaged or broken and needs to be replaced? Use this guide to help you replace it.
A damaged screen bezel can pose a threat to your laptop. The bezel safeguards the screen and enhances the users' experience by providing a tactile edge to hold onto. It also helps prevent accidental screen touches and absorbs shock from impacts.
Without replacement, users risk the device's durability and potential damage during accidental drops or bumps.
Before starting, make sure the laptop is powered off and unplug all cables before beginning any repair.
Was du brauchst
Werkzeuge
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Mehr anzeigen …
  1. Lenovo V14-IIL Screen Bezel Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo V14-IIL Screen Bezel Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Screen Bezel Replacement: Schritt 2, Bild 1 von 1
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Screen Bezel Replacement: Schritt 3, Bild 1 von 1
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Screen Bezel Replacement, Display Assembly: Schritt 4, Bild 1 von 2 Lenovo V14-IIL Screen Bezel Replacement, Display Assembly: Schritt 4, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
  5. Lenovo V14-IIL Screen Bezel Replacement: Schritt 5, Bild 1 von 1
    • Lift up the latch and gently pull the display cable free.
  6. Lenovo V14-IIL Screen Bezel Replacement: Schritt 6, Bild 1 von 2 Lenovo V14-IIL Screen Bezel Replacement: Schritt 6, Bild 2 von 2
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  7. Lenovo V14-IIL Screen Bezel Replacement: Schritt 7, Bild 1 von 1
    • Ensure that all cables and hinges are detached.
    • Lift the display assembly away from the base.
  8. Lenovo V14-IIL Screen Bezel Replacement, Screen Bezel: Schritt 8, Bild 1 von 2 Lenovo V14-IIL Screen Bezel Replacement, Screen Bezel: Schritt 8, Bild 2 von 2
    • Slide the cable hinge cover to the right.
    • Pull the part away from the screen.
  9. Lenovo V14-IIL Screen Bezel Replacement: Schritt 9, Bild 1 von 2 Lenovo V14-IIL Screen Bezel Replacement: Schritt 9, Bild 2 von 2
    • Use the iFixit opening tool to separate the bezel panel.
    • Slide the opening tool all the way around to loosen the bezels on all sides.
    • You may need to use the tool to gently loosen the adhesive tape.
    • Lift away the bezel panel.
Abschluss
Kristen Gismondi
92.209 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
19.481 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 55
