Logitech K480 Metal Plate Replacement
Was du brauchst
Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
Slide a blue pick in to keep the pieces apart while you work on other areas.
Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
Remove the eight 3 mm screws using a Phillips #00 screwdriver
Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
