Einleitung
Use this guide to replace the microphone array assembly in an Early 2020 MacBook Air.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Do not reuse the battery if it is swollen or was deformed in any way during the procedure. The battery is likely damaged and can be very dangerous to reuse—it should be replaced.
This guide involves removing the speakers and battery. You will need new adhesive to properly reinstall the speakers and battery.
Was du brauchst
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
Use a T3 Torx driver to remove the 4.2 mm screw securing the left speaker to the case.
Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
Pull the adhesive strip until it's freed from under the speaker.
Apply heat to the speaker to soften the adhesive underneath.
Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
Remove the left speaker.
Slide the pointed end of a spudger underneath the right speaker cable and pry straight up to disconnect it from the audio board.
Use a T3 Torx driver to remove the 4.2 mm screw securing the right speaker to the case.
Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
Remove the right speaker.
Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
Use a T3 Torx driver to remove two 2.5 mm screws securing the battery tray to the case.
On the left side of the MacBook, use a pair of tweezers to peel back the three black pull tabs on the battery's stretch-release adhesive strips until you can grip them with your fingers.
Grab an adhesive strip's pull tab and slowly pull it out from underneath the battery.
Pull the adhesive strip until it's freed from under the battery.
Repeat for the two remaining adhesive strips on the battery's left side.
Repeat and remove the three adhesive strips from the right side of the battery.
Remove the battery assembly.
If you're installing a new battery, follow the calibration procedure:
Charge it to 100%, and keep charging it for at least 2 more hours.
Unplug and use it normally to drain the battery.
When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery.
Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
Use a pair of tweezers to peel back the tape covering the microphone cable connector.
Use the pointed end of a spudger to lift up the small locking flap on the microphone cable's ZIF connector.
Slide an opening pick underneath the microphone cable to separate it from the upper case.
Slide an opening pick underneath the microphone closest to the center of the MacBook to slice through the adhesive securing it to the upper case.
Lift up to pry the microphone out of its recess in the case.
Use the pointed end of a spudger to carefully pry one of the remaining microphones out of its recess in the upper case.
Remove the third and final microphone from the case.
Eine weitere Person hat diese Anleitung absolviert.
