Einleitung
On the top of the NutriBullet powerbase, there are three white activators that initiate the active blending process. This replacement guide will provide instructions on how to replace these activators.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
Use slight tension to remove the curved base by lifting it upward off of the outside casing.
Wiggle the outside casing upward until it separates from the powerbase.
Place the NutriBullet powerbase on the table so that the white activators are visible. Remove the three rubber protectors from the activators using either tweezers or your fingers.
Turn the NutriBullet powerbase upside down and remove the plastic casing by lifting it up.
Determine which activator(s) fail to work by applying pressure to them. Then, remove the two 15mm screws that hold the activators in place by using the Philips Head 2 screwdriver.
Open up the green switch. The metal tab and black button will fall out. Fiddle around with the metal switch on the inside to snap it back into place and then reassemble carefully. It should make a clicking noise.
54 weitere Nutzer haben diese Anleitung absolviert.
40 Kommentare
Thank you. I would have went nuts looking for the screw under the rubber pieces. Would have probably destroyed the whole machine.
