Magic Bullet NutriBullet Power Cord Replacement
Einleitung
Zu Schritt 1 der AnleitungIs there a tear or cut in your cord? If so, refer to this guide to replace the power cord. This guide will require some soldering experience.
Was du brauchst
Werkzeuge
Before beginning, make sure the device is unplugged.
With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket.
After removing the gray base and silver casing, the wires will now be free and you will have easy access to them.
Gently pull out the two plastic covers at the end of the wires.
Use tape or clamps to hold the wires together for an easy soldering experience.
Using a soldering iron, solder your new wire to the red wire.
Since this guide replacement requires cutting wires, if you want to reassemble this device, you must first re-solder new wires before following the steps backwards to reassemble the device.
3 weitere Personen haben diese Anleitung absolviert.
7 Kommentare
where am I going to be the magic bullet repair
Or
there a service center here in the philippines?
Thank u.
Is there a service centre in Singapore?
I just bought the gadget in Melbourne (from Harvey Norman Nunawarding) last week. We used it yesterday but after one round of spinning, gadget went dead.
What could go round and to fix it at home?
Can I plug the Magic Bullet in 220v?
Where can I get a replacement cable from?
