Zum Hauptinhalt wechseln
Milwaukee 6130-33 Fan Casing Replacement
Brandon Olguin
Brandon Olguin und 3 weitere Mitwirkende
Zuletzt aktualisiert am December 19, 2024
15 Minuten
Mittel
If you notice handling issues with the fan casing of your Milwaukee (6130-33), use this guide. You'll need a TR10 and TR20 screwdriver to replace the casing parts.
The fan casing helps to reduce noise, stability and preventing overheating. Before accessing the casing follow the Safety Brush Springs guide in order to access the interior of the device.
Before replacing the casing, also check the interior once the fan casing is removed. Over time debris and other build up can be the cause of malfunctioning.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Milwaukee 6130-33 Fan Casing Replacement, Safety Brush Springs: Schritt 1, Bild 1 von 3 Milwaukee 6130-33 Fan Casing Replacement, Safety Brush Springs: Schritt 1, Bild 2 von 3 Milwaukee 6130-33 Fan Casing Replacement, Safety Brush Springs: Schritt 1, Bild 3 von 3
    • Remove both 3.5 mm TR10 Torx screws from the carbon brush locks.
    • Turn over the device and perform the same process on the opposite side.
  2. Milwaukee 6130-33 Fan Casing Replacement: Schritt 2, Bild 1 von 2 Milwaukee 6130-33 Fan Casing Replacement: Schritt 2, Bild 2 von 2
    • Remove both springs by pulling outwards from the rotor.
    • When removing, pull on the carbon casing to avoid harming both yourself and the device.
  3. Milwaukee 6130-33 Fan Casing Replacement: Schritt 3, Bild 1 von 2 Milwaukee 6130-33 Fan Casing Replacement: Schritt 3, Bild 2 von 2
    • Using a pair of pliers, squeeze the black cord.
    • Remove by pulling the black wire attached to the brush casing.
  4. Milwaukee 6130-33 Fan Casing Replacement, Fan Casing: Schritt 4, Bild 1 von 2 Milwaukee 6130-33 Fan Casing Replacement, Fan Casing: Schritt 4, Bild 2 von 2
    • Remove the four 4 mm TR20 Torx screws from the gear casing.
  5. Milwaukee 6130-33 Fan Casing Replacement: Schritt 5, Bild 1 von 2 Milwaukee 6130-33 Fan Casing Replacement: Schritt 5, Bild 2 von 2
    • Remove the case head attached to the rotor by pulling it up and off.
  6. Milwaukee 6130-33 Fan Casing Replacement: Schritt 6, Bild 1 von 3 Milwaukee 6130-33 Fan Casing Replacement: Schritt 6, Bild 2 von 3 Milwaukee 6130-33 Fan Casing Replacement: Schritt 6, Bild 3 von 3
    • Remove the four 3.5 mm TR10 Torx screws from the fan casing.
    • Remove the fan casing to access the inside casing.
Abschluss
Brandon Olguin
509 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 44
