Zum Hauptinhalt wechseln
Motorola Moto G60S Daughterboard Replacement
Was du brauchst
  1. Motorola Moto G60S Daughterboard Replacement, Prepare your phone for disassembly: Schritt 1, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Prepare your phone for disassembly: Schritt 1, Bild 2 von 2
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your phone and unplug any cables.
  2. Motorola Moto G60S Daughterboard Replacement, Remove the SIM card tray: Schritt 2, Bild 1 von 3 Motorola Moto G60S Daughterboard Replacement, Remove the SIM card tray: Schritt 2, Bild 2 von 3 Motorola Moto G60S Daughterboard Replacement, Remove the SIM card tray: Schritt 2, Bild 3 von 3
    • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the left edge of the phone.
    • Push the SIM eject tool into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  3. Motorola Moto G60S Daughterboard Replacement, Heat the right edge: Schritt 3, Bild 1 von 1
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Motorola Moto G60S Daughterboard Replacement, Insert an opening pick: Schritt 4, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Insert an opening pick: Schritt 4, Bild 2 von 2
    • Flip your phone over so the display is facing up.
    • Apply a suction handle to the middle of the display's left edge, as close to the edge as possible.
    • Place the tip of an opening pick in the small gap between the back cover and the display.
    • Pull up on the suction cup with a strong, steady force and push the opening pick down at a 45 degree angle until it slides into the gap between the back cover and the display.
    • If you're having a hard time inserting the pick, reheat the adhesive with an iOpener and try again.
  5. Motorola Moto G60S Daughterboard Replacement, Slice the left adhesive: Schritt 5, Bild 1 von 3 Motorola Moto G60S Daughterboard Replacement, Slice the left adhesive: Schritt 5, Bild 2 von 3 Motorola Moto G60S Daughterboard Replacement, Slice the left adhesive: Schritt 5, Bild 3 von 3
    • Both adhesive and clips secure the back cover.
    • During steps that involve sliding the opening pick, keep it angled down at a 45 degree angle.
    • Slide the pick along the left edge down to the bottom left corner, and then up to the top left corner, to release the clips and slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
  6. Motorola Moto G60S Daughterboard Replacement, Heat the top edge: Schritt 6, Bild 1 von 1
    • Flip your phone over and apply a heated iOpener to the back cover's top edge for two minutes.
  7. Motorola Moto G60S Daughterboard Replacement: Schritt 7, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 7, Bild 2 von 2
    • Flip your phone over and rotate the pick around the top left corner.
  8. Motorola Moto G60S Daughterboard Replacement: Schritt 8, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 8, Bild 2 von 2
    • Slide the pick along the top edge to release the clips and slice the adhesive.
    • Leave the pick inserted in the top right corner.
  9. Motorola Moto G60S Daughterboard Replacement: Schritt 9, Bild 1 von 1
    • Flip your phone over and apply a heated iOpener to the back cover's left edge for two minutes.
  10. Motorola Moto G60S Daughterboard Replacement: Schritt 10, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 10, Bild 2 von 2
    • Flip your phone over and rotate the pick around the top right corner.
  11. Motorola Moto G60S Daughterboard Replacement: Schritt 11, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 11, Bild 2 von 2
    • Slide the pick along the right edge to release the clips and slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
  12. Motorola Moto G60S Daughterboard Replacement: Schritt 12, Bild 1 von 1
    • Flip your phone over and apply a heated iOpener to the back cover's bottom edge for two minutes.
  13. Motorola Moto G60S Daughterboard Replacement: Schritt 13, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 13, Bild 2 von 2
    • Flip your phone over and rotate the pick around the bottom right corner.
  14. Motorola Moto G60S Daughterboard Replacement: Schritt 14, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 14, Bild 2 von 2
    • Slide the opening pick along the bottom edge to release the clips and slice the adhesive.
  15. Motorola Moto G60S Daughterboard Replacement: Schritt 15, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 15, Bild 2 von 2
    • Flip your phone over and apply a heated iOpener to the fingerprint sensor on the back cover for two minutes.
  16. Motorola Moto G60S Daughterboard Replacement, Detach the fingerprint sensor: Schritt 16, Bild 1 von 3 Motorola Moto G60S Daughterboard Replacement, Detach the fingerprint sensor: Schritt 16, Bild 2 von 3 Motorola Moto G60S Daughterboard Replacement, Detach the fingerprint sensor: Schritt 16, Bild 3 von 3
    • Adhesive secures the fingerprint sensor to the back case.
    • A fragile cable secures the fingerprint sensor to the motherboard. Be very careful during this step to avoid damaging the cable.
    • Press down on the fingerprint sensor with the flat end of a spudger or your finger.
    • While pressing down on the fingerprint sensor, gently pull up the bottom edge of the back cover until the sensor detaches.
  17. Motorola Moto G60S Daughterboard Replacement, Remove the back cover: Schritt 17, Bild 1 von 3 Motorola Moto G60S Daughterboard Replacement, Remove the back cover: Schritt 17, Bild 2 von 3 Motorola Moto G60S Daughterboard Replacement, Remove the back cover: Schritt 17, Bild 3 von 3
    • Lift the back cover up and remove it.
    • If the back cover is still stuck to the frame, slide an opening pick around the entire perimeter until the cover separates completely.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • Apply new adhesive to the perimeter of the underside of the back cover after cleaning the relevant areas with isopropyl alcohol (>90%) and a micro-fiber cloth.
  18. Motorola Moto G60S Daughterboard Replacement, Detach the fingerprint sensor: Schritt 18, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Detach the fingerprint sensor: Schritt 18, Bild 2 von 2
    • The fingerprint reader is secured to the motherboard cover with light adhesive.
    • Insert the flat end of a spudger under the fingerprint sensor.
    • Gently pry up and detach the fingerprint sensor from the motherboard cover.
    • Don't try to remove the fingerprint sensor yet, as it's still attached to the motherboard by a delicate ribbon cable.
  19. Motorola Moto G60S Daughterboard Replacement, Unfasten the motherboard cover: Schritt 19, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Unfasten the motherboard cover: Schritt 19, Bild 2 von 2
    • Use a Phillips screwdriver to remove the seven 3.9 mm screws securing the motherboard cover.
  20. Motorola Moto G60S Daughterboard Replacement, Unclip the motherboard cover: Schritt 20, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Unclip the motherboard cover: Schritt 20, Bild 2 von 2
    • The motherboard cover is secured with tight clips.
    • Insert the flat end of a spudger in the gap between the frame and the bottom left corner of the motherboard cover.
    • Lift straight up with the spudger to release the clips securing the motherboard.
    • Don't pry against the battery, as this could damage it.
    • This may take take a few attempts. It you're having trouble, try gripping the spudger closer to the flat end.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  21. Motorola Moto G60S Daughterboard Replacement, Remove the motherboard cover: Schritt 21, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Remove the motherboard cover: Schritt 21, Bild 2 von 2
    • Pull the motherboard cover towards the top of the phone to remove it.
    • Make sure to avoid the fingerprint sensor cable when removing the cover, as it can easily rip.
  22. Motorola Moto G60S Daughterboard Replacement, Disconnect the battery: Schritt 22, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Disconnect the battery: Schritt 22, Bild 2 von 2
    • Use the flat end of a spudger to pry up and disconnect the battery cable's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  23. Motorola Moto G60S Daughterboard Replacement, Unfasten the daughterboard cover: Schritt 23, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Unfasten the daughterboard cover: Schritt 23, Bild 2 von 2
    • Use a Phillips screwdriver to remove the seven 3.9 mm screws securing the daughterboard cover.
  24. Motorola Moto G60S Daughterboard Replacement, Detach the graphite film: Schritt 24, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Detach the graphite film: Schritt 24, Bild 2 von 2
    • Adhesive lightly adheres the graphite film to the battery.
    • Insert the pointed end of a spudger under the graphite film on the left side of the daughterboard cover.
    • Lift up and detach the graphite film from the battery.
  25. Motorola Moto G60S Daughterboard Replacement, Unclip the daughterboard cover: Schritt 25, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Unclip the daughterboard cover: Schritt 25, Bild 2 von 2
    • Insert an opening pick between the top left edge of daughterboard cover and the frame.
    • Pry up with the opening pick to release the clips securing the daughterboard cover.
    • During reassembly, press down around the perimeter of the daughterboard cover to engage the clips.
  26. Motorola Moto G60S Daughterboard Replacement, Remove the daughterboard cover: Schritt 26, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Remove the daughterboard cover: Schritt 26, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers or your fingers to remove the daughterboard cover.
  27. Motorola Moto G60S Daughterboard Replacement: Schritt 27, Bild 1 von 3 Motorola Moto G60S Daughterboard Replacement: Schritt 27, Bild 2 von 3 Motorola Moto G60S Daughterboard Replacement: Schritt 27, Bild 3 von 3
    • Use angled tweezers to grip the antenna's black coaxial connector, as close to the connector head as possible.
    • Lift straight up to disconnect the cable.
    • Be gentle when disconnecting the cable, as it's very easy to tear the socket from the daughterboard.
    • Repeat the disconnection procedure on the white antenna cable.
    • To reattach coaxial connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
    • During reassembly, make sure the antenna cables are in their groove on the edge of the phone.
  28. Motorola Moto G60S Daughterboard Replacement: Schritt 28, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 28, Bild 2 von 2
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  29. Motorola Moto G60S Daughterboard Replacement: Schritt 29, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement: Schritt 29, Bild 2 von 2
    • Insert the pointed end of a spudger in the circular cutout on the middle of the top edge of the daughterboard.
    • Pry up until you can grip the daughterboard with your fingers or tweezers.
  30. Motorola Moto G60S Daughterboard Replacement, Remove the daughterboard: Schritt 30, Bild 1 von 2 Motorola Moto G60S Daughterboard Replacement, Remove the daughterboard: Schritt 30, Bild 2 von 2
    • Lift the top edge of the daughterboard up with tweezers or your fingers and pull it towards the top of the phone to remove it.
    • Make sure the interconnect and antenna cables are out of the way so they don't get stuck under the daughterboard.
    • Reinsert the daughterboard at a downward angle to position the USB-C port back into its recess.
  31. Motorola Moto G60S Daughterboard Replacement: Schritt 31, Bild 1 von 1
    • You're left with the daughterboard.
Abschluss
To reassemble your device, follow the instructions in reverse order.
Spencer Day
150.124 Reputation
995 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.648 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 261
