Motorola V60s Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungThis is the guide to remove the battery from the Motorola V60.
Was du brauchst
Werkzeuge
Push in release lever towards top of phone, then use blue spudger to pry case off.
After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
Set cover aside in a safe location.
Carefully grab battery towards bottom of phone.
Lift from bottom and take out of phone, set aside in a safe location.
