Zum Hauptinhalt wechseln
Nokia N70 Display Replacement
Justin
Justin und 5 weitere Mitwirkende
Zuletzt aktualisiert am November 7, 2017
10 - 25 Minuten
Mittel
Was du brauchst
Werkzeuge
  1. Nokia N70 Display Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Display Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Display Replacement: Schritt 3, Bild 1 von 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Display Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the phone.
  5. Nokia N70 Display Replacement, Keypad: Schritt 5, Bild 1 von 3 Nokia N70 Display Replacement, Keypad: Schritt 5, Bild 2 von 3 Nokia N70 Display Replacement, Keypad: Schritt 5, Bild 3 von 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Display Replacement: Schritt 6, Bild 1 von 3 Nokia N70 Display Replacement: Schritt 6, Bild 2 von 3 Nokia N70 Display Replacement: Schritt 6, Bild 3 von 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Display Replacement, Display: Schritt 7, Bild 1 von 1
    • Using a torx T6 screwdriver remove the six 15 mm torx screws.
  8. Nokia N70 Display Replacement: Schritt 8, Bild 1 von 2 Nokia N70 Display Replacement: Schritt 8, Bild 2 von 2
    • Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle.
  9. Nokia N70 Display Replacement: Schritt 9, Bild 1 von 2 Nokia N70 Display Replacement: Schritt 9, Bild 2 von 2
    • Lift the bottom of the display circuit board up and locate the ribbon connection located where the two circuit boards intersect.
    • Remove the ribbon connection that connects the two circuit boards.
  10. Nokia N70 Display Replacement: Schritt 10, Bild 1 von 3 Nokia N70 Display Replacement: Schritt 10, Bild 2 von 3 Nokia N70 Display Replacement: Schritt 10, Bild 3 von 3
    • While pulling back each of the clamps marked in the image, lift out each side of the screen independently.
    • Be careful when using the plastic prying tool to not scratch the display.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Justin
984 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-2, Regan Fall 2011 Mitglied von Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 31
Insgesamt: 8,836
