Zum Hauptinhalt wechseln
OnePlus 8T Screen Replacement
Was du brauchst
  1. OnePlus 8T Screen Replacement, Step 1  Remove the SIM tray: Schritt 1, Bild 1 von 1
    • Before you begin, switch off your phone
    • Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the bottom right edge of the phone.
    • Press firmly to eject the tray
    • Remove sim card tray
  2. OnePlus 8T Screen Replacement, Heat the rear glass: Schritt 2, Bild 1 von 1
    • Switch off your phone.
    • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  3. OnePlus 8T Screen Replacement, Create a gap: Schritt 3, Bild 1 von 3 OnePlus 8T Screen Replacement, Create a gap: Schritt 3, Bild 2 von 3 OnePlus 8T Screen Replacement, Create a gap: Schritt 3, Bild 3 von 3
    • Apply a suction cup to the back of the phone, as close as possible to the center of the bottom edge.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull on the suction cup to create a gap between the rear glass and the frame.
    • Insert the tip of an opening pick into the gap and slide it to the bottom left corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  4. OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 4, Bild 1 von 2 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 4, Bild 2 von 2
    • Insert a second opening under the bottom left corner.
    • Slide the opening pick along the bottom edge to the bottom right corner.
    • Leave the pick in its place to prevent the adhesive from resealing.
  5. OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 5, Bild 1 von 3 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 5, Bild 2 von 3 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 5, Bild 3 von 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick under the bottom right corner.
    • Slide the opening pick along the right edge to the top right corner.
    • Leave the opening picks in their place to prevent the adhesive from resealing.
  6. OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 6, Bild 1 von 2 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 6, Bild 2 von 2
    • Insert a fourth opening pick under the top right corner.
    • Slide it along the top edge to the top left corner to cut the adhesive.
  7. OnePlus 8T Screen Replacement, Slice the remaining adhesive: Schritt 7, Bild 1 von 3 OnePlus 8T Screen Replacement, Slice the remaining adhesive: Schritt 7, Bild 2 von 3 OnePlus 8T Screen Replacement, Slice the remaining adhesive: Schritt 7, Bild 3 von 3
    • Insert a fifth opening pick under the top left corner.
    • Slide the opening pick along the left edge to the bottom left corner to cut the remaining adhesive.
  8. OnePlus 8T Screen Replacement, Remove the rear glass: Schritt 8, Bild 1 von 1
    • Remove the rear glass.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. OnePlus 8T Screen Replacement, Unscrew the motherboard cover: Schritt 9, Bild 1 von 1
    • Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
  10. OnePlus 8T Screen Replacement, Unclip the motherboard cover: Schritt 10, Bild 1 von 3 OnePlus 8T Screen Replacement, Unclip the motherboard cover: Schritt 10, Bild 2 von 3 OnePlus 8T Screen Replacement, Unclip the motherboard cover: Schritt 10, Bild 3 von 3
    • Insert the tip of an opening pick under the bottom left corner of the motherboard cover.
    • Use the opening pick to lift the motherboard cover up and release the plastic clips that hold it in place.
  11. OnePlus 8T Screen Replacement, Remove the motherboard cover: Schritt 11, Bild 1 von 1
    • Remove the motherboard cover.
  12. OnePlus 8T Screen Replacement, Disconnect the battery: Schritt 12, Bild 1 von 2 OnePlus 8T Screen Replacement, Disconnect the battery: Schritt 12, Bild 2 von 2
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  13. OnePlus 8T Screen Replacement, Unscrew the daughterboard cover: Schritt 13, Bild 1 von 1
    • Use a Phillips screwdriver to remove the seven 3.8 mm-long screws securing the daughterboard cover.
  14. OnePlus 8T Screen Replacement, Remove the daughterboard cover: Schritt 14, Bild 1 von 3 OnePlus 8T Screen Replacement, Remove the daughterboard cover: Schritt 14, Bild 2 von 3 OnePlus 8T Screen Replacement, Remove the daughterboard cover: Schritt 14, Bild 3 von 3
    • Insert the tip of an opening pick under the top edge of the daughterboard cover.
    • Remove the daughterboard cover.
  15. OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: Schritt 15, Bild 1 von 2 OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: Schritt 15, Bild 2 von 2
    • Use a spudger to disconnect the first fingerprint sensor connector by prying it straight up from its socket.
  16. OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: Schritt 16, Bild 1 von 2 OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: Schritt 16, Bild 2 von 2
    • Use a spudger to disconnect the second fingerprint sensor connector by prying it straight up from its socket.
  17. OnePlus 8T Screen Replacement, Disconnect the interconnect cable: Schritt 17, Bild 1 von 2 OnePlus 8T Screen Replacement, Disconnect the interconnect cable: Schritt 17, Bild 2 von 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  18. OnePlus 8T Screen Replacement, Disconnect the antenna cables: Schritt 18, Bild 1 von 3 OnePlus 8T Screen Replacement, Disconnect the antenna cables: Schritt 18, Bild 2 von 3 OnePlus 8T Screen Replacement, Disconnect the antenna cables: Schritt 18, Bild 3 von 3
    • Carefully disconnect the two antenna cables by prying them straight up from the daughterboard.
  19. OnePlus 8T Screen Replacement, Unscrew the daughterboard: Schritt 19, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 3.1 mm-long screw securing the daughterboard.
  20. OnePlus 8T Screen Replacement, Separate the daughterboard: Schritt 20, Bild 1 von 2 OnePlus 8T Screen Replacement, Separate the daughterboard: Schritt 20, Bild 2 von 2
    • Use an opening pick to pry up the daughterboard.
    • Use your fingers to separate the daughterboard from the phone assembly.
  21. OnePlus 8T Screen Replacement, Disconnect the screen: Schritt 21, Bild 1 von 2 OnePlus 8T Screen Replacement, Disconnect the screen: Schritt 21, Bild 2 von 2
    • Use the flat edge of a spudger to pry up and disconnect the screen connector from its socket at the frame.
  22. OnePlus 8T Screen Replacement, Heat the screen: Schritt 22, Bild 1 von 1
    • Heat an iOpener and apply it to the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  23. OnePlus 8T Screen Replacement, Create a gap: Schritt 23, Bild 1 von 2 OnePlus 8T Screen Replacement, Create a gap: Schritt 23, Bild 2 von 2
    • Apply a suction cup to the right edge of the screen.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull the suction cup up with strong, steady force to create a gap.
    • Insert the point of an opening pick into the gap and slide it to the bottom right corner.
  24. OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 24, Bild 1 von 3 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 24, Bild 2 von 3 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 24, Bild 3 von 3
    • Insert a second opening pick at the bottom right corner.
    • Leave both opening picks in their place to prevent the adhesive from resealing.
  25. OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 25, Bild 1 von 2 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 25, Bild 2 von 2
    • Slide the opening pick along the bottom edge to the bottom left corner to slice the adhesive.
    • Leave the pick in its place to prevent then adhesive from resealing.
  26. OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 26, Bild 1 von 3 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 26, Bild 2 von 3 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 26, Bild 3 von 3
    • Insert a fourth opening pick under the bottom left corner.
    • Slide the opening pick along the left edge to the top left corner to slice the adhesive.
  27. OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 27, Bild 1 von 2 OnePlus 8T Screen Replacement, Slice the adhesive: Schritt 27, Bild 2 von 2
    • Slide the opening pick along the top edge to the top right corner.
    • When you slice near the front facing camera, insert only the tip (5 mm) of the opening pick to avoid damaging the camera.
    • Do not remove the screen completely yet. The display cable is still threaded through the midframe.
  28. OnePlus 8T Screen Replacement, Separate the screen: Schritt 28, Bild 1 von 2 OnePlus 8T Screen Replacement, Separate the screen: Schritt 28, Bild 2 von 2
    • Thread the display flex cable through the gap in the frame.
  29. OnePlus 8T Screen Replacement, Remove the screen: Schritt 29, Bild 1 von 1
    • Remove the screen.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card.
Abschluss
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Adriana Zwink
48.810 Reputation
167 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
5 Kommentare
Thank you iFixit & Adriana! These intructions are spot on and guided me perfectly through a successful front and rear screen replacement.
Jim M.
Jim Malinak - Antwort
Hi Jim, we're happy to hear that we were able to help you with your repair!
Adriana Zwink -
I broke my phone one plus 8T just now, how should i proceed next ? I want it really to be fixed but not sure if its still in a condition that i can be repaired
Akshay Raina - Antwort
Do you remove the front earpiece speaker grill as well when you remove the front screen? As I am putting the screen back on, not sure if the top of the screen needs to be under the grill, but for some reason, it isn't matching or it's bulging from that area.
Erik Stejanko - Antwort
WARNING!
You have to remove the sim card tray before removing the daughterboard. At nno point in this guide is this mentioned. You risk damaging the daughterboard when trying to pry it loose.
Staffan Näs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 124
Letzte 30 Tage: 526
Insgesamt: 21,509
