Philips Norelco 5801XL Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace the rechargeable battery in the Philips Norelco 5801XL. The steps should be followed exactly as listed in the guide. Some soldering skills are required. Be sure to handle with care. For help with soldering: click here.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Using a plastic opening tool, separate the front housing from the back housing.
Carefully pull the housing apart.
Remove the plastic bracket using a plastic opening tool.
Pry from the inside of the bracket towards the outside of the housing to remove it.
Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
Remove the bracket. It will pull straight out.
Desolder the contacts where the battery connects to the circuit board.
Straighten the battery contacts and pull them through the opposite side of the circuit board.
3 weitere Personen haben diese Anleitung absolviert.
