Zum Hauptinhalt wechseln
Replacing the ball bearing in Squeaky Ceiling Fan
SengChoy Liew
SengChoy Liew und 4 weitere Mitwirkende
Zuletzt aktualisiert am May 8, 2024
1 Stunde
Mittel
Anleitung eines Community-Mitglieds
This repair guide will solve the squeaks sound of the ceiling fan after few years of operation. Youtube guide available show how-to replace the two wear out ball bearing.
Einführungsvideo
  1. Replacing the ball bearing in Squeaky Ceiling Fan, Remove the plastic cover: Schritt 1, Bild 1 von 2 Replacing the ball bearing in Squeaky Ceiling Fan, Remove the plastic cover: Schritt 1, Bild 2 von 2
    • First, remove the mounting screws of the plastic cover located along the brim, farthest from the centre.
  2. Replacing the ball bearing in Squeaky Ceiling Fan, Removal of the Iron cage: Schritt 2, Bild 1 von 2 Replacing the ball bearing in Squeaky Ceiling Fan, Removal of the Iron cage: Schritt 2, Bild 2 von 2
    • The iron cage is firmly secured by three screws.
    • Out of the six mounting screws located along the inner circle, three of them will be the mounting screws for the iron cage.
    • Remaining six screws will be the mounting screws for the fan blade.
  3. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 3, Bild 1 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 3, Bild 2 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 3, Bild 3 von 3
    • Remove the wiring from the terminal block and the capacitor from the bracket.
    • Unscrew the 13mm mounting bolt to remove the supporting rod.
  4. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 4, Bild 1 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 4, Bild 2 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 4, Bild 3 von 3
    • Remove the safety cord.
    • Use plier to loosen the holder.
    • The back plate can be removed once all the electric components are removed.
  5. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 5, Bild 1 von 2 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 5, Bild 2 von 2
    • Be sure to keep the O-ring safe.
    • Knock off the back plate by positioning it up-side down.
  6. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 6, Bild 1 von 2 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 6, Bild 2 von 2
    • Use three crawl puller, to remove the bearing.
    • Spray lubricant prior to extraction.
  7. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 7, Bild 1 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 7, Bild 2 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 7, Bild 3 von 3
    • Use a two crawl puller to remove the bearing located 4mm away from the tip.
    • Alternatively, it can be knocked off using a chisel from behind through the hole.
    • A long chisel becomes handy !
  8. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 8, Bild 1 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 8, Bild 2 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 8, Bild 3 von 3
    • Use three sockets to level the rotor core, while giving the bearing a final push.
  9. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 9, Bild 1 von 2 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 9, Bild 2 von 2
    • A 3" long PVC tube of 6/8 " inner diameter, is used to install the new bearing (6302z for this model of fan).
    • Rubber mallet is used to punch the PVC tube during installation.
  10. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 10, Bild 1 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 10, Bild 2 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 10, Bild 3 von 3
    • Use a rubber mallet to install the other bearing onto the shaft. Rubber mallet or wooden mallet prevents damage to the bearing.
    • The same PVC tubing can be used to give the bearing a final push.
  11. Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 11, Bild 1 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 11, Bild 2 von 3 Replacing the ball bearing in Squeaky Ceiling Fan: Schritt 11, Bild 3 von 3
    • Apply mechanical grease around the inner wall of the iron cage.
    • Be sure to install the O-ring.
    • Installation of fan requires electrical knowledge. Certified personnel are required to install it back on the ceiling.
Abschluss
19 weitere Personen haben diese Anleitung absolviert.
SengChoy Liew
969 Reputation
3 Anleitungen geschrieben
5 Kommentare
my ceiling fan would sometimes not start and making rumbling sounds (bearings) i did not want to replace or tear down so lifted plastic cover on top and liberally sprayed machine oil over exposed bearing & through slots underneath wd 40 this has cured problem perfectly just dry bearings would probably be better to use spray grease if you have --cheaper than new fan or bearings and only a few minutes work
daveorme - Antwort
My fan was not working what probelm
Govardhan Yadagiri - Antwort
Thanks! I took apart my fan, thank you to your precise instructions. Used lithium grease and right now, enjoying quiet fan in my bedroom
Chris murie - Antwort
price of the ceiling fan bearing
tophan das - Antwort
muchas gracias porel aporte , muy util y bien explicado
saludos cordiales
cuismi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 85
Letzte 30 Tage: 264
Insgesamt: 64,362
