Zum Hauptinhalt wechseln
SGH-A117 keypad replacement
Stephanie Isaac
Stephanie Isaac und 2 weitere Mitwirkende
Zuletzt aktualisiert am June 18, 2018
30 Minuten - 1 Stunde
Mittel
Action Shots
Benötigt Bessere Bilder
The keypad is something that is used quite often on a phone when texting or emailing. Due to the constant use of the keypad, the keypad can possibly become worn out.
The process of replacing the keypad is a bit challenging and requires patience and attention to detail. The equipment you are working with is very delicate and if not assembled properly, it will break.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. SGH-A117 keypad replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the battery by pressing the battery lock down and slide the battery cover away.
  2. SGH-A117 keypad replacement: Schritt 2, Bild 1 von 1
    • Lift the bottom of the battery and then move it up and away.
  3. SGH-A117 keypad replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
  4. SGH-A117 keypad replacement: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, gently pry open the back piece of the phone.
    • Make sure to do this very carefully, as the back part of the phone is very thin and fragile.
  5. SGH-A117 keypad replacement: Schritt 5, Bild 1 von 1
    • Use the metal prying tool to gently flick up the rectangular connector. (Because this device is on the smaller side, the rectangular connector may only need a simple flick with the prying tool)
    • Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
  6. SGH-A117 keypad replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to gently pry up the motherboard.
    • You may need to pry the motherboard up from several angles in order to remove it.
  7. SGH-A117 keypad replacement, Keypad: Schritt 7, Bild 1 von 1
    • After the connector has been removed you will gently pull off the mother board, which will reveal the rubber keypad.
  8. SGH-A117 keypad replacement: Schritt 8, Bild 1 von 1
    • Replace the faulty keypad, and reassemble the phone.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015
USFSM-STEWART-F15S1G1
5 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 238
