Samsung BD-JM57C Motherboard Replacement
Einleitung
Zu Schritt 1 der AnleitungFollow this guide to replace an old or faulty motherboard in your Samsung BD-JM57C Blu-ray player.
The motherboard in the Blu-ray player allows all the other important components such as the disc drive and Wifi card to communicate with one another. An old or faulty motherboard will prohibit these components from communicating with each other resulting in a Blu-ray player that will ultimately not turn on.
Before taking apart the Blu-ray player and replacing the motherboard, look at the troubleshooting page for the Samsung BD-JM57C and see if your problem can be resolved.
Was du brauchst
Werkzeuge
Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
Remove the cover by sliding it up and then out.
Disconnect the two ribbons that connect the disc drive to the motherboard.
Push in on the two metal tabs on the side of the disc drive.
Push forward to slide the disc drive out of the casing.
Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
Lift the cage up to remove it.
Remove the rubber spacer on the edge of the case holding the cord in place.
Remove the power cord from the device.
After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
Pull the motherboard up to remove it from the device.
