Einleitung
Prerequisite-only screen repair guide.
This guide instructs you to replace only the display while leaving the original frame, logic board, and battery in place. Note: some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires you to transplant all of your phone's internals and install a new battery. This procedure is very different, so make sure you have the correct part before starting this guide.
If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
Was du brauchst
Prepare an iOpener and heat the back of the phone along its left edge for about two minutes. This will help soften the adhesive securing the back cover.
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from outside the phone, you'll be slicing through the adhesive in the areas shown:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
Secure a suction cup to the back cover, as close to the heated edge as possible.
Lift the back cover's left edge with your suction cup, opening a slight gap between the back cover and the frame.
Slide your opening pick along the left edge of the phone to slice through the adhesive securing the back cover.
Continue slicing through the adhesive along the bottom edge of the phone.
Again, it may help to leave the opening pick in place and grab another one for the following step.
Use the point of a spudger to pry up and disconnect the fingerprint sensor flex cable.
Then, use the flat end of your spudger to gently snap the connector into place by pressing it straight down.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the back cover.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Use a spudger to gently pry up the plastic in the marked areas to pop the clips free.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
Using a spudger, disconnect the display by carefully prying up its flex cable connector from the socket on the motherboard.
Heat the bottom edge of the display to soften the adhesive securing it to the phone.
If possible, press a suction cup into place near the bottom edge of the display.
Pull up on the suction cup to lift the display's lower edge, opening a slight gap between the display and the frame.
Insert an opening pick into the gap.
Slide your opening pick along the lower edge of the display to separate the adhesive underneath.
Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
Reheat the iOpener and apply heat to the left edge of the display for at least two minutes.
Use your opening pick to separate the adhesive under the left side of the display.
Use your opening pick to separate the adhesive under the right edge of the display.
Gently work your opening pick under the top edge of the display to separate the adhesive underneath.
Use your picks as needed to finish separating the adhesive beneath all areas of the display.
Route the display's flex cable through its hole in the frame in order to fully separate the right edge of the display.
Remove the display.
After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
