Samsung SGH-A237 Camera Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will instruct the user how to replace the camera of the Samsung SGH-A237 cell phone. Prior experience of replacing the camera is not necessary.
Was du brauchst
Place the phone on a flat surface with the camera facing upwards.
Have a designated space to keep track of each small part.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Open the phone.
Remove the two rubber soft screw covers below the viewing screen using a pair of tweezers.
Loosen the screws under the soft screw covers using a Phillips #00 screwdriver.
Locate the black cover plate on the back side of the viewing screen. It will show the AT&T and Samsung logos.
Look on the right side of the phone for the crease in between the black back cover and the front silver cover of the viewing screen.
Pry the cover plate off using a plastic opening tool.
Identify the metal bracket that covers the internal body.
Identify the metal tabs surrounding the metal bracket mentioned in the previous step.
Remove the metal bracket using a small pick or a Phillips #00 screwdriver.
Close the phone.
Find the camera on the upper part of the phone. It will be displayed as a small black circle.
Follow the copper ribbon connected to the camera downward to the black connection port.
Pry up the black connector using a pick. This should lock the black connector into an upward position, which will release the copper ribbon connected to the phone's camera.
Gently grasp the copper ribbon attached to the camera using a pair of tweezers.
Gently pull copper ribbon towards the camera. This should pull the copper ribbon out completely.
