Zum Hauptinhalt wechseln
SteelSeries Nimbus+ Controller Battery Replacement
Was du brauchst
  1. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: Schritt 1, Bild 1 von 2 SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: Schritt 1, Bild 2 von 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the sticker: Schritt 2, Bild 1 von 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    Frag FixBot
  3. SteelSeries Nimbus+ Controller Battery  Replacement, Unscrew the back cover: Schritt 3, Bild 1 von 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    Frag FixBot
  4. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: Schritt 4, Bild 1 von 2 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: Schritt 4, Bild 2 von 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    Frag FixBot
  5. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: Schritt 5, Bild 1 von 2 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: Schritt 5, Bild 2 von 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    Frag FixBot
  6. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: Schritt 6, Bild 1 von 2 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: Schritt 6, Bild 2 von 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    Frag FixBot
  7. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: Schritt 7, Bild 1 von 2 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: Schritt 7, Bild 2 von 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    Frag FixBot
  8. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: Schritt 8, Bild 1 von 3 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: Schritt 8, Bild 2 von 3 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: Schritt 8, Bild 3 von 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    Frag FixBot
  9. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: Schritt 9, Bild 1 von 3 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: Schritt 9, Bild 2 von 3 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    Frag FixBot
  10. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the back cover assembly: Schritt 10, Bild 1 von 1
    • Remove the back cover assembly.
    Frag FixBot
  11. SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: Schritt 11, Bild 1 von 2 SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: Schritt 11, Bild 2 von 2
    • The battery is held in place by mild adhesive.
    • Insert the edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and loosen the adhesive.
    Frag FixBot
  12. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the battery: Schritt 12, Bild 1 von 1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Make sure to align the battery and the back cover of the controller correctly during reassembly.
    Frag FixBot
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
Eine weitere Person hat diese Anleitung absolviert.
Adriana Zwink
66.974 Reputation
167 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.812 Anleitungen geschrieben
1 Kommentar zur Anleitung
Useless directions. The battery has 3 connectors. What is the mode? Where can you buy it? Polarity? If you have one with the right voltage and amps; but has two connectors what's do you do?
All this so-called repair guide says is: "This is how you open the case". Fantastic and then what???
Baldy - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 60
Insgesamt: 2,255
