Zum Hauptinhalt wechseln
Toshiba Satellite A665-S5170 Battery Replacement
Chelsea Teague
Chelsea Teague und 2 weitere Mitwirkende
Zuletzt aktualisiert am September 19, 2023
1 Minute
Sehr einfach
If your battery will not retain charge when your computer is unplugged from the adaptor, your battery may be faulty, and you may need to replace it. Replacing your Toshiba Satellite A665-S5170 battery does not require any tools and takes relatively little time.
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite A665-S5170 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A665-S5170 Battery Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A665-S5170 Battery Replacement: Schritt 3, Bild 3 von 3
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Baylor, Team 4-5, Williams Fall 2016 Mitglied von Baylor, Team 4-5, Williams Fall 2016
BU-WILLIAMS-F16S4G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 1,255
