Zum Hauptinhalt wechseln
Vacuum Cleaner Brush Roll Replacement
Kaitlyn Sheets
Kaitlyn Sheets und 6 weitere Mitwirkende
Zuletzt aktualisiert am July 26, 2024
20 Minuten
Mittel
Follow these instructions to disassemble an upright vacuum cleaner and remove debris like hair or string that may be preventing the floor brush from spinning.
*Exact part locations and the number of screws may vary according to the device model.
Was du brauchst
Werkzeuge
  1. Vacuum Cleaner Brush Roll Replacement, Brush Roll: Schritt 1, Bild 1 von 1
    • Be sure to unplug the device from the wall outlet before disassembling.
    • Remove the bottom head of the vacuum cleaner by pressing the push button.
  2. Vacuum Cleaner Brush Roll Replacement: Schritt 2, Bild 1 von 2 Vacuum Cleaner Brush Roll Replacement: Schritt 2, Bild 2 von 2
    • Carefully unscrew the 6 screws with a Phillips screwdriver. Set aside.
  3. Vacuum Cleaner Brush Roll Replacement: Schritt 3, Bild 1 von 1
    • Separate the top portion of the head from the bottom.
    • Make sure not to pull off or damage the connected wires.
  4. Vacuum Cleaner Brush Roll Replacement: Schritt 4, Bild 1 von 1
    • Slip off the belt.
  5. Vacuum Cleaner Brush Roll Replacement: Schritt 5, Bild 1 von 2 Vacuum Cleaner Brush Roll Replacement: Schritt 5, Bild 2 von 2
    • Pull the brush roll from its slots.
  6. Vacuum Cleaner Brush Roll Replacement: Schritt 6, Bild 1 von 2 Vacuum Cleaner Brush Roll Replacement: Schritt 6, Bild 2 von 2
    • Use scissors to cut strings and other debris from the brush roll. Avoid cutting the bristles.
  7. Vacuum Cleaner Brush Roll Replacement: Schritt 7, Bild 1 von 1
    • Return the clean brush roll and re-situate the belt to secure it in place.
Abschluss
To reassemble your device, follow the disassembly instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Kaitlyn Sheets
129 Reputation
1 Anleitung geschrieben
Oakland University, Team 6-12, Walwema Winter 2016 Mitglied von Oakland University, Team 6-12, Walwema Winter 2016
OAK-WALWEMA-W16S6G12
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 70
Insgesamt: 3,207
