ZTE Blade X Max Front Camera Replacement
Einleitung
Zu Schritt 1 der AnleitungIf the front camera of your ZTE Blade X Max is not functioning—blurry image, scratched lens—and you have already been through our troubleshooting guide, you will have to replace it.
This guide requires removing the back of the phone. You will have to use heating products to complete this guide. If you are using the iFixit iOpener, or a heating pad, be sure to follow the instructions for that particular product.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
Use the tweezers to remove the panel.
Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
Once the motherboard is exposed, locate the front camera connection in the top right corner of the motherboard.
Use the tweezers to remove the front camera.
