Zum Hauptinhalt wechseln
ZTE Blade X Max Midframe Replacement
Kristen Gismondi
Kristen Gismondi und 4 weitere Mitwirkende
Zuletzt aktualisiert am March 12, 2025
15 - 20 Minuten
Mittel
Studierende im Gange!
This guide explains how to replace the Mid Frame in a ZTE Blade X Max in step-by-step format. Make sure your device is powered off and you have access to a clear workspace before you begin.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Blade X Max Midframe Replacement, Back Cover: Schritt 1, Bild 1 von 2 ZTE Blade X Max Midframe Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
    • It will take about ten minutes for the adhesive to be heated enough to remove the backing.
    • You will have to reheat the iOpener or heating pad a few times.
  2. ZTE Blade X Max Midframe Replacement: Schritt 2, Bild 1 von 3 ZTE Blade X Max Midframe Replacement: Schritt 2, Bild 2 von 3 ZTE Blade X Max Midframe Replacement: Schritt 2, Bild 3 von 3
    • Slide the Jimmy along the under backing and lightly push the plastic up.
    • You will hear a snapping sound as you slide the Jimmy along the backing. This is from the closures releasing. There should be seven total closures on either side of the device, and three on the top and bottom.
  3. ZTE Blade X Max Midframe Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the backing from the phone once the closures are released.
    • If you do not open all of the closures on the backing do not attempt to pry it off.
    • Be careful when opening the back of the phone. The fingerprint scanner is connected by a thin film that will tear if pulled too roughly.
  4. ZTE Blade X Max Midframe Replacement: Schritt 4, Bild 1 von 3 ZTE Blade X Max Midframe Replacement: Schritt 4, Bild 2 von 3 ZTE Blade X Max Midframe Replacement: Schritt 4, Bild 3 von 3
    • Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
  5. ZTE Blade X Max Midframe Replacement: Schritt 5, Bild 1 von 3 ZTE Blade X Max Midframe Replacement: Schritt 5, Bild 2 von 3 ZTE Blade X Max Midframe Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
    • Use the tweezers to remove the panel.
  6. ZTE Blade X Max Midframe Replacement: Schritt 6, Bild 1 von 2 ZTE Blade X Max Midframe Replacement: Schritt 6, Bild 2 von 2
    • Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
  7. ZTE Blade X Max Midframe Replacement, Midframe: Schritt 7, Bild 1 von 1
    • Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
  8. ZTE Blade X Max Midframe Replacement: Schritt 8, Bild 1 von 3 ZTE Blade X Max Midframe Replacement: Schritt 8, Bild 2 von 3 ZTE Blade X Max Midframe Replacement: Schritt 8, Bild 3 von 3
    • Remove the sixteen 1mm Phillips #000 screws from the midframe of the phone.
  9. ZTE Blade X Max Midframe Replacement: Schritt 9, Bild 1 von 3 ZTE Blade X Max Midframe Replacement: Schritt 9, Bild 2 von 3 ZTE Blade X Max Midframe Replacement: Schritt 9, Bild 3 von 3
    • Use the Jimmy to remove the midframe from the device.
Abschluss
Kristen Gismondi
92.173 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.470 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 211
