ZTE Blade X Max Motherboard Replacement
Einleitung
Zu Schritt 1 der AnleitungIf primary functions of your ZTE Blade X Max are failing—failure to power on, multiple functions failing—and you have gone through the troublshooting guide, then you may have to replace your motherboard.
This guide requires removing the back of the phone, which is not meant to be removed by the consumer. You will have to use heating products to complete this guide. If you are using the iFixit iOpener, or a heating pad, be sure to follow the instructions for that particular product.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
Use the tweezers to remove the panel.
Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
Remove the single 1mm Phillips #000 screw from the motherboard.
Detach the five flat connectors.
Use tweezers to remove the protective foam surrounding the headphone jack at the top left of the device.
Eine weitere Person hat diese Anleitung absolviert.
