Zum Hauptinhalt wechseln
ZTE Lever Power Button Replacement
Michael Gonzalez
Michael Gonzalez und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 10, 2025
25 Minuten
Mittel
Bessere Einleitung
Follow this replacement guide to replace the power button on a ZTE Lever smartphone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Lever Power Button Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Power Button Replacement: Schritt 2, Bild 1 von 2 ZTE Lever Power Button Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Power Button Replacement: Schritt 3, Bild 1 von 2 ZTE Lever Power Button Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Power Button Replacement: Schritt 4, Bild 1 von 2 ZTE Lever Power Button Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Power Button Replacement: Schritt 5, Bild 1 von 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Power Button Replacement, Volume Buttons: Schritt 6, Bild 1 von 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Power Button Replacement: Schritt 7, Bild 1 von 3 ZTE Lever Power Button Replacement: Schritt 7, Bild 2 von 3 ZTE Lever Power Button Replacement: Schritt 7, Bild 3 von 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Power Button Replacement: Schritt 8, Bild 1 von 2 ZTE Lever Power Button Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Power Button Replacement: Schritt 9, Bild 1 von 2 ZTE Lever Power Button Replacement: Schritt 9, Bild 2 von 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Power Button Replacement, Power Button: Schritt 10, Bild 1 von 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Power Button Replacement: Schritt 11, Bild 1 von 2 ZTE Lever Power Button Replacement: Schritt 11, Bild 2 von 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
Abschluss
USF Tampa, Team S5-G2, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 230
