Zum Hauptinhalt wechseln
ZTE Lever Rear Camera Replacement
Michael Gonzalez
Michael Gonzalez und 3 weitere Mitwirkende
Zuletzt aktualisiert am September 26, 2021
15 Minuten
Mittel
Follow this guide to do a rear camera replacement on your ZTE Lever smart phone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Lever Rear Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Rear Camera Replacement: Schritt 2, Bild 1 von 2 ZTE Lever Rear Camera Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Rear Camera Replacement: Schritt 3, Bild 1 von 2 ZTE Lever Rear Camera Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Rear Camera Replacement: Schritt 4, Bild 1 von 2 ZTE Lever Rear Camera Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Rear Camera Replacement: Schritt 5, Bild 1 von 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Rear Camera Replacement, Rear Camera: Schritt 6, Bild 1 von 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Rear Camera Replacement: Schritt 7, Bild 1 von 3 ZTE Lever Rear Camera Replacement: Schritt 7, Bild 2 von 3 ZTE Lever Rear Camera Replacement: Schritt 7, Bild 3 von 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Rear Camera Replacement: Schritt 8, Bild 1 von 2 ZTE Lever Rear Camera Replacement: Schritt 8, Bild 2 von 2
    • Using a plastic opening tool, disconnect the camera from the motherboard.
  9. ZTE Lever Rear Camera Replacement: Schritt 9, Bild 1 von 1
    • Remove the camera from the phone.
Abschluss
USF Tampa, Team S5-G2, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 128
