Zum Hauptinhalt wechseln
ZTE Maven 2 Motherboard Replacement
Kristen Gismondi
Kristen Gismondi und eine weitere beteiligte Person
Zuletzt aktualisiert am May 16, 2024
Keine Schätzung
Mittel
Bessere Einleitung
Fehlende Angaben
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Maven 2 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 ZTE Maven 2 Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 ZTE Maven 2 Motherboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Motherboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Motherboard Replacement, MicroSD Card: Schritt 3, Bild 1 von 2 ZTE Maven 2 Motherboard Replacement, MicroSD Card: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Motherboard Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Motherboard Replacement: Schritt 5, Bild 1 von 3 ZTE Maven 2 Motherboard Replacement: Schritt 5, Bild 2 von 3 ZTE Maven 2 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 ZTE Maven 2 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 ZTE Maven 2 Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Motherboard Replacement: Schritt 7, Bild 1 von 2 ZTE Maven 2 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Motherboard Replacement: Schritt 8, Bild 1 von 2 ZTE Maven 2 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kristen Gismondi
92.282 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.537 Anleitungen geschrieben
Ein Kommentar
Merci d'avance pour votre aide
St armant Narcisse - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 71
