ZTE Maven 3 Back Cover Replacement
Einleitung
Zu Schritt 1 der AnleitungThe back cover of a phone might require replacement due to physical damage, cracks, or wear over extended use. Damage to the back cover can compromise the phone's structural integrity, potentially exposing internal components to dust, moisture, or further harm.
Swapping the back cover not only restores the device's aesthetics but also safeguards its internal mechanisms, ensuring continued functionality and protection.
Was du brauchst
Werkzeuge
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
