Zum Hauptinhalt wechseln
ZTE Maven 3 Daughterboard Replacement
Emma Thiboutot
Emma Thiboutot und eine weitere beteiligte Person
Zuletzt aktualisiert am January 2, 2024
9 Minuten
Mittel
Replacing the daughterboard or charging port in a phone becomes necessary when these components suffer damage or malfunction, leading to charging issues or connectivity problems. Physical damage, corrosion, or wear and tear can impair the functionality of the charging port, resulting in difficulties charging the device or establishing connections with other devices.
Swapping out these components ensures seamless charging, data transfer capabilities, and overall usability of the phone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Maven 3 Daughterboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 ZTE Maven 3 Daughterboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 ZTE Maven 3 Daughterboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Daughterboard Replacement, Battery: Schritt 2, Bild 1 von 3 ZTE Maven 3 Daughterboard Replacement, Battery: Schritt 2, Bild 2 von 3 ZTE Maven 3 Daughterboard Replacement, Battery: Schritt 2, Bild 3 von 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Daughterboard Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Daughterboard Replacement: Schritt 4, Bild 1 von 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Daughterboard Replacement: Schritt 5, Bild 1 von 2 ZTE Maven 3 Daughterboard Replacement: Schritt 5, Bild 2 von 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Daughterboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
  7. ZTE Maven 3 Daughterboard Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Please locate the black wire that’s attached to gold plates on the left side of the device.
    • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
  8. ZTE Maven 3 Daughterboard Replacement: Schritt 8, Bild 1 von 2 ZTE Maven 3 Daughterboard Replacement: Schritt 8, Bild 2 von 2
    • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
    • 2 adhesive ribbon cables (green circles).
    • One ribbon cable that slides out (orange circles).
    • Three ribbon cables that pop in and out (yellow circles).
  9. ZTE Maven 3 Daughterboard Replacement: Schritt 9, Bild 1 von 3 ZTE Maven 3 Daughterboard Replacement: Schritt 9, Bild 2 von 3 ZTE Maven 3 Daughterboard Replacement: Schritt 9, Bild 3 von 3
    • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
  10. ZTE Maven 3 Daughterboard Replacement: Schritt 10, Bild 1 von 2 ZTE Maven 3 Daughterboard Replacement: Schritt 10, Bild 2 von 2
    • Grab the opening pick and work it into the edges of the motherboard.
    • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
    • Remove the motherboard and put it aside.
  11. ZTE Maven 3 Daughterboard Replacement, Daughterboard/Charging Port: Schritt 11, Bild 1 von 2 ZTE Maven 3 Daughterboard Replacement, Daughterboard/Charging Port: Schritt 11, Bild 2 von 2
    • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
Abschluss
Emma Thiboutot
699 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team 3-1, Konn Fall 2023 Mitglied von UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 52
